What kind of rear end is in it?
stock 8 3/4 with a 3.23 posi. tried a 3.55 and the results are the same. i think i have a chassis issue and ain't smart enough to resolve it.
I'm not sure about this ... BUT maybe the posi is
taking a dump.. but I'm not sure if only one tire
would be slipping all the time..(I guessing that
when you changed gears you used the same posi)
