All I can say is the 73121 springs I used to run before moving to a roller cam held up well and they're not even in Lunati's "premium" spring lineup.
I think most of the springs available today from a wide variety of companies are really made by only a few actual spring companies. If you spend some time searching the spring selections of three or four different cam companies, you can often find the identical specs offered by most or all of them.
