Re: Steering coupler question
[Re: TC@HP2]
#1204343
04/03/12 01:12 AM
04/03/12 01:12 AM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
Uni-bodies flex and parts move around. If you don't have reinforcements on the uni-body and the steering mount in particular, you're taking a chance putting a solid coupling in there.
Absolutely correct. Not really dangerous, but once you snap the nylon breakaway pin, or trash the upper bearing, you've set yourself up for lots more work and parts-chasing.
Flaming River's setup works fine with their column (only), because it is a close-tolerance collapsible deal with no breakaway pin.
Rick
