Quote: I bought just the 70 Challenger trunk lid piece from Metro(having an SE I don't need separate Qtr pieces). It seemed to be a fine piece but the problem I encountered is that the little cut-out on the trim that allows for the retaining clips to be inserted lines-up with the location of the outermost retainers. This is true of both ends. So I am stuck unless I re-drill the holes for the ends.
Anyone else have this issue? Maybe the outside holes in my decklid are too far out to start with...
IIRC I had this problem too. The clips can install in two directions. When you install them the wrong way they line up with the cut-out. Try taking them off and installing them the other way.
