I really like getting the hands on experience with this motor build and I'm learning a lot as we go, but there are several areas that are completely foreign to me and installed valve spring heights is one of them..
Since I posted the question earlier, I believe I have found a set of springs that will work with these B1 heads.. and will not need any modifications to the installed height.. So thanks for the lesson.. you guys are great!!
