If you look they are welded together from the factory. So welding on them won't be a problem.
I know that, but that is in a factory and the housings probably aren't welded with the axles, bearings and seals in there. Who knows what they did here, the welds were kind of sloppy too.
Sloppy probably means they didn't get enough heat for a good weld... Which means they probably didn't hurt anything..
"The Armies of our ancestors were lucky, in that they were not trailed by a second army of pencil pushers."
