That and a dremel will fix you up. There's a chart with slot lengths for advance amounts for stock distributors.
Stock style distributor, get a diagram for taking it apart. There's a snap clip down the center of the shaft up top to remove the top plate. You can do the whole deal in about 1 hr if you are quick.
