the "RPM" and the "RPM air gap" are the same exact runners, just a different floor in the manifold to give the air gap underneath. The LD340 is a step away from the stock intake toward the RPM. The LD340 still makes some pretty sharp corners compared to the RPM but it is better than stock.
