Quote: Simple if you ask me, most small block cars you see are A-bodies, and A-body guys are also low budget guys (same goes for many SB powered B-body owners for that matter), a good running Six Pack setup will run you in the range of $1,500-$2,500.00 all in, and that's as much as many of those guys have in thier entire car.
WOW what a low blow. The reason I built an A body was because of weight. My car is 3100 lb with me in it. Throw in a stroker small block (not cheap) and it goes! And yes I have had six packs. I dont now, but I do like them. Your comment was low budget.
