What are you guys using for spring clamps? Bolts and flat steel? Actual spring clamps? and from where.
One inch wide by 1/4 inch thick straps and 3/8 bolts and nuts work good for me, make your own with a hacksaw and 3/8 drill motor Measure to see how many feet of the one inch strap you need( see how many clamps and how long you want each strap X 2 and you got it and buy it at a local steel supply place Installed them with all the weight on the car, don't jack the car up and let the springs and rear end hang down
Cool thanks, that probably what I would have done anyway $$$$ ya know, but I wondered what the other side was using.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
