Did you check your pinion angle after changing the rear springs? I bet it is off and is contributing to your problems
I did check and it's OK
Quality shocks are always a good idea
I just installed edelbrock shocks. I'm sure there are better quality shocks but for my use I thought they might be OK - Opinion?
I'm going to try the pinion snubber. Thanks for the 1.5" recommendation from stumpy and roadhazard. I'll have to look into the QA-1s.
After I order it and install I'll get back.
Thanks to all.
Frank ![](/ubbthreads/images/graemlins/beer.gif)
Remember - 2 wrongs don't make a right - but 3 rights make a left!
