You need to find out the actual DTC set to properly diagnois the issue. FWIW, they are known for throttle body issues and it may be your problem. It may have just froze up causing the butterfly to stick. Since they are drive-by-wire they are more trouble prone than a standard cable operated unit.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
