North Alabama
It seems to me on eddies 440-1 motor he made about 800hp and sprayed 700hp,,,,,,, now hes making almost 1200hp an spraying less in to pick up a couple tenths??? i dont get it??? wiht properly setup chassis and more spray i think he could beat any of the cars...
yeah, it has way less nitrous on it and yeah it will go much faster....but...the first pass at BG was the first time this motor had EVER been down the track on 2 kits. Some may go out and go balls to the wall right off the bat and spray the snot out of it with both kits, but that is not my style. It is Eddie's car and he can do as he pleases, but if the plan calls for just "pilling it up and hoping for the best" with no testing, I'm out. Want no part of anything like that. Eddie is leading his class by a bunch, Larson has more if needed, trust me. Larry is playing to win, if Eddie throws down a number, you can bet Larry will respond. The 7.75 he went at BG was with only 15lbs of boost.
Monte
