Hi Jim, it looks like you used a sealer between the door skin and the reinforcing plate. Was that just to hold the plate in place or was there another reason.
I noticed that too after I posted the picture. In all honesty I can't remember if I had a good reason at the time (present day senior moment...). I don't recall if the vendor mentioned it or not so so it may be nothing more that it seemed like a good idea at the time. I'm pretty sure it is nothing more than regular RTV so functionally it would provide a seal in case water ever migrated down past the window whiskers, although not much of a chance of that happening as the car does not see much rain... The RTV could also prevent it from any rattles or vibrations. Good eye.
It's in the installation instructions, and the vendor is Dynamic Renovation
