Here's a pic of where I am in the process.
Do you just destroy the old rubber bushing to get them out and thread the steel armature off the sway bar end 'eyelet'? Then press new bushings into each armature? Does the steel armature come apart maybe?
After that - what do I need to press the new bushing over the bar end 'eyelet'? The FSM ain't helping. It says these aren't serviceable bushings and to replace the assembly. Great.
Thanks for any advice.
-Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
