Yep, I always do the t-belts at 60k, however these are non-interference engines, so no huge loss if it snaps on you.
I would remove, clean and then reinstall the AIS motor on the throttle body. Sometimes that helps, other times does nothing. Have you tried checking for codes just in case by chance the computer knows something is wrong?
