Hey all. Im working on a little 89 Reliant K. It has a TBI 2.2.
It idles all over the place sometimes and is real weak off the line. (i know its only a 2.2.. but my 88 aries was much stronger off the line). I went to check the timing and with the coolent temp sens plugged in it jumps all over the place. With it unplugged it jumps up and down a deg or 2.
Also, the timing belt has a mark on it from the grove in the tensioner pulley. There are no cracks and it doesnt look like it jumped timing. What is the life expectancy on these belts?
Thanks.
