1971 Plymouth 'Cuda originally 383-4, now 440-6
OK, so I just got my engine running. In the process of overhauling and installing my engine, I bought a new wire harness from Year One. 440-6 electronic ignition harness. I had a Tuff brand single wire alternator that I installed. I am using a stock type voltage regulator on the firewall and just disconected the one on the back of the new alternator. Here is my problem. The harness has connections for a four post balist resistor. I got one down at autozone for a 1975 V8 truck. My alternator is putting out 16-16.5 Volts at the battery and I think it might be due to the wrong balist resistor.
Can anyone confirm this and maybe give me a part number that I can get at Autozone or O'Rielys, somewhere local.
Thanks.
