Re: Engine should die, right?
[Re: RapidRobert]
#1168300
01/30/12 10:36 PM
01/30/12 10:36 PM
Posts: 559 Scottsdale, AZ
kenz
Scottsdale, AZ
The engine has never run correctly.
Might switch gears & check true TDC on the dampener & dont remem if you mentioned what it is timed at. rotor phasing acceptable. EGR closed. Kind of WAG ing here. I enjoy 318's, wish I was closer to give you a hand
We verified tdc and degreed the cam to make sure everything was correct. Plus it was a good learning experience for my son. :-)
The timing is set at 18 degrees btdc. There is no egr.
Not sure about rotor phasing but I forgot to mention that we tried both a rebuilt stock distributor and a MP unit. Made no difference.
We've spent so much trying new parts that I guess we should have just bought a crate motor. :-(
Thanks again for the help. Ken
Entire Thread
kenz
01/30/12 04:36 AM
kenz
01/30/12 04:38 AM
RapidRobert
01/30/12 05:09 AM
05dakota
01/30/12 05:23 AM
Secret Chimp
01/30/12 05:39 AM
Jim_Lusk
01/30/12 05:55 AM
newvcode
01/30/12 10:13 PM
kenz
01/31/12 01:41 AM
RapidRobert
01/31/12 02:21 AM
kenz
01/31/12 02:36 AM
RapidRobert
01/31/12 02:42 AM
RapidRobert
01/30/12 10:25 PM
OldMoparMan
01/31/12 01:46 AM
Supercuda
02/01/12 01:10 AM
kenz
02/01/12 02:06 AM
