Change the intake gaskets & get the composition ones & use Permatex "high tack" the red stuff in a spray can & use a thick/wide carefully placed swath of clear silicone on the front/rear rails in place of the gaskets letting it sit up overnight as the supplied front/rear gaskets can be too thick but if a massive vac leak it'd have to be an intake/head interface gasket/alignment prob I'd think
