Radiator support in '68 should have the Order # stamped on, look on the upper yoke near the battery. Order # is also on fender tag. Might also be #s stamped on left quarter trunk rail like on my '68 RR.
The SO# is on the core support , should be on the face that the rad may partially block, and under the trunk gasket on the drivers side . The VIN is NOT stamped anywhere on a 68 other than the tag on the dash .
