The soggy performance may have PLENTY to do with the rear axle gearing. Its quite likely that you have a 2.76 or 2.94 gearing. If you follow the advice of Mr Yuck, along with stepping up to a 3.55 or 3.91 gear, you'll transform the car from a decent cruiser to a tire smoking hot rod.
