Ok, would you say that a stiffened chassis will make a car react quicker? I would, also if you say hit a pothole? With the normal unstiffened chassis do you think the suspension is gonna travel the same amount as hitting that same pothole with no chassis flex? See you are thinking about ride, im talking about what my car does before and after. So in the context that you are using yes my car is probably rougher from a "ride" stand point because now I am getting deeper into the rates of my tbars,shocks and swaybar that used to get help from the chassis soaking some of the impact up. But I am certainly not gonna go to a smaller tbar to improve my "ride".
