No Problem. I run 2 regulators off a fuel log. One regulator for the motor is set at 7 pounds. Other Regulator runs both fuel solenoids and is set at 5 pounds. First stage is 57 square and 2 stage has a 64 square pill. I run a McLeod long style pressure plate with a Ram 6 puck disk. Best ET so far with both stages is 10.44 130.73 mph. Thats with a 2 1/2 inch exhaust with flowmasters. I know there is some more in it. Drove it to the track and drove it home.
