I have three 741 cases and two are 741 cone style Sure-grips. The two Sure-grips are 3.55 and 3.91. I just want to swap the ring & pinion from the 741 that has the open diff into one of the 741 cases with the Sure-grip. Just wanted to make sure the r&p is the same between the open and the SG.
I would sell one or both of those POS cone type chucks and buy a clutch type sure grip to swap in .
edit ... oh wait that doesn't answer your original question.
Do as the guy above me says , just swap a cone type into the 3.23 and have the open put into the one you take it from ...
