Re: Yes ,Lickity Split is making progress
[Re: BigFish69]
#1146411
12/31/11 07:04 PM
12/31/11 07:04 PM
Posts: 9,871 MI, usa
dvw
MI, usa
Doug could you post a closer pic of the way you mounted the tach to the dash. thanks Tom
I turned a piece of round aluminum 1.375"x.500". Drilled and tapped it for 3/8-24. Welded the original spacer that came with the tach mount to the top. The 2nd part is 2.50x1.375x.125 I bent it at about a 30 degrees. The flat support needs some gussets welded as it is to flexible. Doug
Entire Thread
dvw
12/29/11 05:43 PM
JAKE68
12/29/11 06:38 PM
dvw
12/29/11 07:18 PM
JAKE68
12/29/11 08:13 PM
Dartin
12/29/11 09:46 PM
dvw
12/30/11 01:52 AM
dvw
12/30/11 01:53 AM
dvw
12/30/11 01:56 AM
dvw
12/30/11 01:58 AM
cbs
12/30/11 03:06 AM
dvw
12/30/11 03:15 AM
blown572dart
12/30/11 03:18 AM
dvw
12/30/11 03:19 AM
Dartin
12/30/11 03:22 AM
dvw
12/30/11 03:24 AM
dvw
12/30/11 03:28 AM
Troublemaker427
12/30/11 03:29 AM
bigdad
12/30/11 03:33 AM
megajoltman
12/30/11 04:07 AM
1967dartgt
12/30/11 05:14 AM
Al_Alguire
12/30/11 06:09 AM
racerx
12/30/11 03:05 PM
tboomer
12/30/11 04:16 PM
dvw
12/30/11 04:34 PM
JERICOGTX
12/30/11 10:28 PM
Dave Watt
12/30/11 10:51 PM
Gary Robbins
12/30/11 11:15 PM
BigFish69
12/31/11 05:16 AM
dvw
12/31/11 11:04 PM
dvw
12/31/11 11:09 PM
BigFish69
01/01/12 12:04 AM
bee71mopar
01/01/12 03:04 PM
B G Racing
01/02/12 12:53 AM
