i need to push my rearend back on my 71 dart for tire clearence, who has done this and does it affect traction or should i cut the rear quarter in front of tire and keep rearend in stock location thanks guys
How much do you need to move it
about 3/4 of an inch
You can put 3/4" plates in front of your front hangers
and then (if you want) put a set of sliders on the
rear to eliminate the shackles... it wont hurt your
weight distribution bad enough to hurt in traction
mine has the spring relocation kit done i am trying to fit a 30.5x11.0 on a 12" wheel, i would have to weld up the hole on the rearend perch and redrill 3/4" forward . i talked to caltracs they said it wouldn't hurt anything if i did it that way thanks guys
