Re: 904 Trans Leaking alot
#114370
09/03/08 11:23 AM
09/03/08 11:23 AM
Posts: 75,042 U.S.S.A.
JohnRR
U.S.S.A.
just rechecked it, leak is comming from the kickdown lever area 100% sure of it!...whats there that leaks?? and do i still have to remove the pan & VB to replace?
There are 2 seals , both require linkage removal and one MAY require you to remove the valve body .
There is a seal in the case , that one can be done withthe special tool , there is also one between the gear selector and the throttle valve control shaft , incorrectly called kickdown , that one you ony need to remove the top lever , an e clip and the washer , seal is under it , becareful you don't let it drop should you decide to try it with the VB in the trans . clean the shafts and that area good before pulling the seal that way you don't get dirt in under the seals or damage the seals sliding them back over rusty gritty shafts .
