We've run two 500 cu in engines w/ the six pac set-ups both a little under 600hp. One used 69 center w/87s outboard, the other 66 center and low 80's ouboard.
I would guess that if you used 64s and 84s you're not to far off, and the not pulling past 6000 might be from something other than jetting.
