to lower the front coil overs are the trick.They do not screw up the front end settings or handling Did you use their upper control arms also?
Hotchkiss is the only ones that I know of that have the bracket to reloate the upper A arm rear attachment point . This sets the plane of the A arm shaft to what would be parrell to the t bar. This helps eliminate the front end changes during travel.
home of the
Sox and Martin Hemi Duster
