The low deck is roughly 7% shorter so as Dan said it's not really as significant as some think. However the rotating mass is that much ccloser to the crank and the low deck will have a lower center of gravity all else being equal.
any block is only as strong as it's thinnest bore.
Thew main advantage to the low deck ( to me) is they used to be cheap to find and the smaller journals on both the rods and mains (when you go 2.200) just helps the bottom end spin a little easier. and generally lighter is (if little more) extra insurance for when you over-rev. Headflow, cam and compression pretty much determine the sweet spot and the rev cieling, lighter bottom ends just get there a little easier and are 'less brutal' to themselves at thigh rpm.
Expert machining is the key to a great running motor, Typically experienced builders can tell how well a motor will run by the way it falls together, and also how well (or poorly) it ran by how it comes apart.
WIZE
World's Quickest Diahatsu Rocky (??) 414" Stroker Small block Mopar Powered. 10.84 @ 123...and gettin' quicker!
https://www.youtube.com/watch?v=-mWzLma3YGI
In Car:
https://www.youtube.com/watch?v=PjXcf95e6v0
