What do you mean by "built too much"???
Is it a driveability issue??? Soft low-end throttle response?
What's been done to the mech. ignition curve??
What carb and carb tuning so far??
Typically many guys bolt on a carb and drop in the distributor, set total advance, and then the dissappointment begins when they want to street drive it.
R.I.P.- Gary "Coop" Davis 02/09/68-05/13/04
