Both engines would have the same compression ratio, and lets say, the same compression height, but different rods, giving a different rod ratio (from reading past posts/arguements on this site, I thought the rod/stroke debate was WAY overated as far as performance goes, it has an effect on longevity of the engine, but not the performance). These theoretical engines would also have good flowing heads.
