Mark, I was just showing you that the dist block and prop valve how are made together.If you are changing to disc front you will need the metering one also. Don't be confused the metering block is a extra valve attached to the dist block.It is different then the prop valve. Early 70 E body w/disc had all 3 but after Jan 70 went to the 2 put together.
Hope this helps
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
