Hi Bob, I thought that was the case and I questioned this but I was told I needed 2 valves for non powered disc brake cars (I am converting from drums up front to the 11 3/4 junkyard setup). Here is the second valve they said I needed. Also what is the metering valve? Is that just for powered discs?
