Quote: Sure it is the pan? I had a bad dipstick tube that leaked around the "O" ring seal. The CRT cast pan is pretty nice at $155, but is a deeper pan.
This is where mine is leaking. Tried a new o-ring and it did not help. I think that it might be the the bore, but have not looked.
What did you find to fix your leak?
I put the Mopar ATF RTV around and under the "O" ring of the dipstick tube. That stuff really works. It is the black RTV the factory used to seal the oil pans on the new cars that don't use a pan gasket.
