Just a FYI for you.. You can get an 8.8 from a pull a part for 150.. The one to get comes in a ford explorer 95 up body style. Disk brakes, posi, 3:73 gears or 4.10 and 31 spline axles and they are almost the same width as your b body rear end.. maybe 1" shorter depending on the year.
59 1/2" wide on the ford explorer axle And that is rotor to rotor..
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
