if you can find someone to narrow the housing there are cheap aftermarket axles for the 9 inch---randys sells the 9,s in any inch increment for about $100 each---so you could get a 28,29,30----if you start looking for a 28.5 inch the set will cost about $500 for a custom cut---bob
