Kaptain Kuda was right after checking everything again and it still shutting off I two footed it for a couple of miles and now the PCM must have reset because it isn't stalling and is running very smoothly. Thanks for all the suggestions, I really appreciate it.
Howard
Glad you got it worked out!
FYI, any time the battery is run dead, or disconnected for other maintenance, etc. this will happen.
**Photobucket sucks**
