Those were known for sucking oil in the intake... also
check the under side of the throttle body for carbon
which screws up the idle air motor... clean that with
carb cleaner or brake cleaner... also see if you get
a O2 code... the O2 sensor could be fouled which
will give bad performance and bad mileage
