It could also be lean. Going from a full exhaust to open exhaust you'll need to richen it up.
i was thinking it was rich so i jetted down the center carb. didnt make a difference.
i havent noticed any exhaust leaks. may need to put washers under the header bolts, they may be bottoming out
Gen 3 power 6.22@110, 9.85@135
Follow @g3hemiswap on instagram
performance only racing, CRT, ultimate converter, superior design concepts, ThumperCarbs
