i couldn`t work out how to get the right front nut onto a challenger decklid. the cuda decklids had all the holes in the inner skin to access the nuts but on a challenger??? see attached pics of a luggage rack on a challenger.
all the best
frank.
Why do you need to get to the nut? It's a nut-sert & if properly installed it is locked to the sheet metal & won't spin...
Correct that's what item #2 is in the engineering drawing, a "riv-nut", installed just like a pop rivet, except it has threads internally....just like what holds your side-view mirrors on
