You have a stock 440-hp minus the HP exhaust manifolds. That will hurt you. As-is with those lo-po exhausts, I'd say you're probably putting out around the same HP as a stock 440-HP, 375. I'd imagine headers would be worth a good hp increase, probably 20-25hp for sure, enough to get you to the 400 mark.
