In my opinion, a reproduction tag can cast doubt on an otherwise honest car down the road. If you have a lot of other documentation, the repro tag adds nothing to the value. It might make you feel warm and fuzzy as the current owner, but it will be spotted a mile away.
@theshakerproject: If you really want to have a tag in your enginebay: Let the fake tag being produced but instead of the last six digits of your VIN in the lower right bottom let there be "repro" stamped in. In that case everyone knows it is not original, including the novices. And you have told it the spectator without waking doubts of your car or intentions.
Carsten
Whenever I see a reproduction tag on a car that the owner is trying to pass off as the original tag, I assume that the block and trans have also been restamped and are not original.
1969 Coronet R/T Y2 Y2 P6X X9 V8X
1967 Satellite 383 4speed
