Most on here will tell you ATI.
However, we went with one of these http://www.professional-products.com/dampersProductchrysler.php on my motor as it also isn't turning over 7K and Scott has had really good results in the past with them.
The only thing to note is remove each screw around the orange ring and add a dab of Loctite to em.
