Dragula is correct on all points. No there's no way to move an EZ VE table to the XFI. But if you car is running well with the EZ, and the learning has had a chance, then your target AF numbers are good. So you can use the same targets with the XFI.
The self learning algorithms for cruise and WOT that the XFI uses is the same as the EZ so it would still work. I'm thinking of writing up a step-by-step procedure for setting up the XFI "Cranking and After Start" fuel tables. It's not that hard.
