They block of the original pump hole with a machined phenolic block, the plug where the push rod goes is where the actuator goes and seals with a flat Oring. I have to use this pump if I want a mechanical pump on my world block. You cannot grind enough to get a carter to fit. Tim
http://www.racepumps.com/FuelPumps-Street.html
