Unless you plan to move up to PSO's, Predators, or B1/TS heads, I wouldn't do it. 572 will be plenty of CI for those heads, and you can run aluminum rods if you want to with 2.200 crank pin with no clearance issues. With the 4 3/4 in stroke you need a special pan, and are limited to steel rods. JMO.
