I run 2 inch hedman headers with jw bell no starter fittment issues with the late model small stater. Just make sure you use the jw flywheel kit. They have an adapter with special flywheel bolts. Also the kit has a bushing for the starter nose cone as well as five starter shims. so you will have shim the starter .
