OK, Air gap bolt holes line up "right down broadway"
with NO end seals and NO gaskets.
I would think I'd still be off if it were a really bad mismatch.
Y'all think it's in the ballpark, or do I need to
set the new fel-pros in place (again, no end seals) and double check?
On another, much more serious note, these heads were max-ported, and a few days ago, I noticed a 'void' (or so I thought) on the wall of the intake port divider.Small, like BB sized.Noted to self to address later.
Later came tonight, and I realized that all 4 intake port divider walls had the same issue.The 1/4 inch VC bolt holes were slightly broken through into the port divider.I didn't use super long VC bolts or anything, and I do not remember seeing these'holes' before I installed the intake.Maybe there was a little oil in the VC bolt holes and I hydraulic'ed the bottom out of the holes??I have about an hour of runtime on the motor, so I now need to decide if the heads have to come off.as far as the breakouts, I will just JB them and smooth off,then use 1/4"studs and nuts on the VCs.
The 'chips' would be roughly 1/16" to 1/8" in diameter, and maybe .020 thick, maybe slightly thicker, I dunno.If they are loose in the chambers and manage to wedge against the piston wall,(If they haven't already) it will score the cylinder and maybe damage the piston.As it is now, they already went thru the valves, so whatever happened there, is done.
Thoughts on both?
Thanks, C
